I worked on a 35.5 ? last year for a broker. The windless is run by a relay under the chain locker. there was a low current line from the control switch to the relay and the power to the switch had a breaker, then a larger line (#6 or #8 wire as I recall) from the battery to the relay and on to the windless. You'll have to trace both circuits down to find the problem
