Found main fuse in engine compartment
I had the same issue after motoring all day and finally traced it down to a fuse on the port side of the engine toward the back/stern of the compartment. It's an inline fuse with a plastic holder and it was hiding behind the main wiring bundle. Yours may be located slightly different since our engine has been replaced once. I just had to reach into the compartment, grab the harness, tweak the fuse holder open, reposition the fuse (it was still good), and close the fuse holder - all with one hand since I couldn't get both in there. Sort of tricky, but it only took 20 minutes and it restored all power and I didn't have to short the starter with my screwdriver to start it anymore.Cheers!-Doug"Second Wind"Dana Point, CAdouglas@gillett.com
