No one owns a Mariner? Really?
Jul 23, 2020
20
4 posts in 3 years? And one of those posts was about an outboard motor and not the actual boat.
I bought my Mariner 32 about 6 months ago, and I've spent that time trying to become acquainted with her. She is a solid sturdy vessel, if not a bit odd and quirky. If anyone who owns a Mariner should frequent this forum--if you know of any resources where I could find original blueprints, plumbing or electrical diagrams, or anything else for these boats, I'd appreciate it.
For anyone else thinking of buying a Mariner, these are a few of my impressions:
She is full keel, and she is as smooth as butter in foul weather. When other boats are heeling 90 degrees, she is gently rocking back and forth like a cradle.
These boats are obviously rare, and it appears that much love and care went into the design of every square foot. There was no dearth of mahogany and teak, and quality stock parts which, even 40 years later, still hold up. These boats are certainly no Hans Christian, but they are also a far cry from the mass produced assembly line vessels that got churned out like so many plastic bathtub toys.
I won't win any races. She is heavy, but faster than you'd expect, and although that Catalina will get there a day earlier, I'll get there a day happier. And really, isn't the point of life the journey rather than the destination?
Like any boat of this age, fittings and hoses and other odds and ends wear out, and so it is a constant effort keeping her updated (stuff wear outs or breaks every other week), but the skeleton is adamantium and the core is solid. Even if all the "small stuff" breaks, the boat will still get you where you need to go and stay afloat while doing it.
My only real complaint is the LOA at 32'. They did a really good job of fitting a 36' boat into a 32' space, but I'm 6'2" and still bump my head when going into the Vberth, and you have to be a midget to fit comfortably into the head. Even smaller female guests have found that space too cramped. If it was a choice between this or a 36' Hunter, I'd still go with the Mariner, but only because I'm a solo sailor. I've heard there are larger Mariners, and it would be interesting to see the inside of one of those if any are still out and about anywhere.
Doug S
Apr 11, 2021
2
Mariner 36 Saginaw Bay
I have a Rhoads 19 I picked up to restore. I think they are about the same thing. I’ve owned it a few years it’s been in my barn can’t seem to get the time I need. I look at it every time I go in there and marvel at her awesome lines. Have fun/good therapy this summer that’s what boats are for.
Yes, same boat with a cabin and slightly altered rig. The Rhodes 19 is the foundation hull.
-Will (Dragonfly)
Aug 22, 2023
28
Mariner 32 Ketch Olympia
I own the M32 Ketch, very solid.
This boat was built by Clair Oberly, in Long Beach CA.
Older versions had plywood incorporated in the cabin wall build.
Many had rotten plywood because of Leaks in windows, handrails and leaky fittings.
This vessel has No plywood in the cabin top, it is laid up much thicker, with stiffening boards tabbed into areas for handrails ect.
I through bolted the cabin top handrails, with 1/4 inch stainless and nylon nuts and flat washers.
Shouldn't be coming loose any longer.
Resealed all windows, so no more leaks.
Leaks can develop at the deck seam, and those points are under a large Toe rail.
That would be a real job should some decide to address that.
Of Course lifeline stanchions need to be looked at, and in my case all were removed and Resealed with backing plates.
These boats have Bowsprits, they do need to be removed and at least Inspected and repaired and recoated if Nessessary.
Exterior Chainplates should be inspected, and corrosion or looseness must be addressed.
These vessels do have a shell liner, So your going to have to locate where the plates and Chainplate bolts are, cut holes in the liner and fabricate trim covers.
Lots of beautiful wood inside, it all needs care, but worth the effort.
As far as sailing? solid vessels!
Not fast upwind like my sloop was, but these boats were meant for long tracks in the Trades.
Not inland racing.
Great cruising boats.
259
Catalina Capri 22 Capri EXPO 14.2 1282 Stony Point
Rented Rhodes 19 in Oyster Bay LI in the 80's. Mr Rhodes could be seen in his house overlooking the bay watching with a telescope. Tried to meet him but no one could put me in contact. Loved that boat.
