Rick
OK heres what happened this weekend. I installed new plugs and did everything everyone has suggested. When it came time to crank the engine the batteries where of course dead. No problem I used the portable battery I got for just such a day. When I hooked it up (positive to positive, negative to negative) just like I had it the weekend before and cranked the engine,CLICK. No starter except for the first click of it engaging. To make things worse SMOKE coming off the starter wire and the plastic on the battery terminal was melting. When I turn the power off at the main the starter again makes a sound. Mind you, this is exactly the same set up I had the week before when it cranked over just fine but didn't start. I suspect the lack of battery allowed the solenoid to switch but wasn't enough to turn the engine.Of course at this point the First Mate insisted that a call to a mechanic was neccesary. Today I got the call back. He wants me to realize that I need a new engine! Something in diesel at $5000.00. Does the story so far sound like a wrecked engine? Has anyone ever got water back from the muffler and lived to tell?
