No Engine Alarm buzzer when key is on
Nov 30, 2008
44
Hunter Legend 375 Sidney BC
Low Oil pressure switch is good, oil pressure at switch is good, continuity of yellow/white wire to buzzer is good. Buzzer works with test switch. Reason I’m asking this question is I cleaned my engine, removed and tagged all the wires to do so, put them back where they came from and now no low oil pressure alarm when key is turned on.
Jan 4, 2006
7,472
That statement doesn't fit. If you have pressure at the switch, no alarm. Please explain.
First question, do you get an alarm if you short the (+) wire at the switch to ground ?
The above is on a 2GM20F.
Nov 30, 2008
44
Ralph,
I removed the pressure switch held my finger over the hole and oil squeezed out. I also checked the switch, I put my tester on the terminal and on the body while pushing the switch open by a long needle inserted in the end to open the switch. No buzzer when wire is shorted to ground with key on.
Mar 6, 2008
1,429
See posting #2, short the wires to see if you get alarm. If you do, then bad pressure switch, not uncommon.
Jan 7, 2011
5,886
Oday 322 East Chicago, IN
Do you mean when the key is on, but the engine is not running?
Greg
Jan 4, 2006
7,472
If I read you correctly, you had the switch in your hand and used a long needle to press against the open end of the switch. Did the resistance change when you moved the needle in and out of the switch. Not entirely clear here.
This appears to be the crux of the whole problem :dancing: . The alarm MUST sound when the wire is shorted to ground BUT it doesn't. What is the voltage between the (+) disconnected wire and the ground ? This will tell us where to start the search.
Nov 30, 2008
44
I checked it but I checked a lot and can not remember. I will check when back at boat tomorrow. Thanks
Nov 30, 2008
44
answer to your first part yes I had the switch in my hand and when I pushed the needle in the switch opened and the meter displayed no continuity. Thanks
Mar 6, 2008
1,429
Do you have the wiring diagram for your boat? It will help tracking down the problem. On my engine this circuit is part if the fuel lift pump power. Did some wire come loose there?
Likes: ggrizzard
May 24, 2004
7,202
CC 30 South Florida
The Test Switch only affects the engine temperature circuit to the buzzer which would otherwise not be activated by turning the key as the engine would not normally be in an overheated condition. Grounding the wire to the oil pressure sensor mimics the response of a good working sensor. Make sure there is power flowing to that wire when the key switch is turned on. You should have 12V to ground. If you have power and the grounded wire does not activate the buzzer then the buzzer has an internal problem and would need to be replaced. You could piggy back to the engine temperature sensor terminal and the buzzer should sound when turning the key, but if it activated while the engine was running you would not know if the problem is temperature or oil pressure. It could be a temporary fix. Them buzzers are expensive.
Nov 30, 2008
44
Benny, All good points I will check and try the piggy back when nectar the boat.
Nov 30, 2008
44
Ralph Johnstown
Ralph,
No there is no alarm when wire to oil pressure switch is shorted to ground.
Thanks
Jan 4, 2006
7,472
No, that's not the important part.
That will tell you almost the entire story of this Sherlock Holmes "Whodunit". Maybe a little more filling in around the edges, but this will tell you what's going on in there.
