No bottom paint
Mar 26, 2023
14
macgregor 26s shell point
I just bought a Macgregor 26 s that i plan to store on a trailer. Some guys from the local boat club were looking at it and said it had no bottom paint. Not sure what that means. it has a nice gel coat on the bottom. Do i need to have the bottom painted.
When speaking of bottom paint, one is usually speaking of anti-fouling paint. No need if the boat on a trailer. If the boat is left in the water for a week or so, as might happen during a vacation, then a pressure washer will make short work of any slime that is on the bottom.
I have this pressure washer
... get something similar and if you ever leave the boat in the water for more than a day or two, give the bottom a quick wash to knock the slime off.
Likes: jodyjuli
Joe
Jun 1, 2004
8,259
Use toilet bowl cleaner to get the crud off quickly. A bucket of diluted acid based toilet cleaner, (it's cheap at Smart&Final), a long handled pot brush and a garden hose works well if the power washer's broke. That said, if you find you like to weekend on the hook alot, you'll be surprised how fast the slime/algae can appear. Therefore, slapping on a couple coats of inexpensive ablative bottom paint is a pretty easy project. But the paint on sale, get the least expensive you can find, a roll of tape and disposable rollers... easy peasy.
3,051
Beneteau 343 Slidell, LA
I just bought a Macgregor 26 s that i plan to store on a trailer. it has a nice gel coat on the bottom. Do i need to have the bottom painted.
Just be careful with the amount of time it remains continuously in the water. I noted on your profile that you are in Florida, where it is normal for water temps to reach into the 80's during summer months. All types of growth are more prolific in that kind of environment. Many years ago, I had a fiberglass runabout with no bottom paint that I allowed to remain in water (during summer), in a marina, for approximately one week. The entire bottom was covered with algae, slime, & a few barnacles. Took hours to clean it with scrapers and stiff brushes. That was last time that I made that mistake.
LloydB
Jan 15, 2006
927
Macgregor 22 Silverton
My boat gets crud when sitting in a slip over the summer but the pressure washer takes care of that faster than any coat of paint that I could put on. I am in cold freshwater so if that were to change or I couldn't easily pressure wash then I would go with ablative.
capta
Jun 4, 2009
5,006
Have an artist come in and paint a great white facing away from your hull and scare anybody coming at you when you are heeled over.
Apr 11, 2020
801
MacGregor 26s Scott's Landing, Grapevine TX
Add me to the "no you do not need bottom paint" crowd. When I bought my 26S, the previous owner kept it on the trailer, just as you plan to do. No bottom paint. This is ideal, as even the best anti-fouling paints will not be as "slick" as a good, blister-free gel coat.
Since I keep my boat in a slip (fresh water), I decided to apply an epoxy barrier coat to avoid blistering, and an anti-fouling coat to discourage algae growth.
If you do have the boat in the water long enough for algae to start growing (2 weeks in the summer in fresh water, less in salt water), be sure to remove it as soon as possible after you haul it out. The longer it stays, the harder it is to deal with later. A 6" plastic scraper and a wet towel will be all you need.
Should you decide to keep your boat in a slip, you will want to consider applying an epoxy barrier coat, then an antifouling coat, ablative or otherwise.
Likes: jodyjuli
Mar 26, 2011
3,838
Corsair F-24 MK I Deale, MD
In Florida it will foul quickly, so I'd limit it to 1-week in the water unless you love scrubbing, and you will still have some.
Likes: FastOlson
