Good evening all,
I will be bringing a boat down the coast in May and might have to use the ICW in NJ. In looking at the charts I see a bridge just south of AC that has a Fixed Clearance of 35 ft? Assuming that is correct i'll have to go on the outside . Another Fixed at 35ft at Peck Bay ?
just want to make sure I'm not missing anything. I would rather go the outside anyway but wanted to have the ICW as an option if the weather turns bad.
just wanted some one with more experience to check my info and make sure
I'm correct.
Coming from NY I will have to run the ocean side past Sandyhook then I could go the inside from Barnegats Bay to Atlantic City, then due to the low bridges I'll have to go back outside from AC to Cape May. ???
I'll be on an Irwin 10/4 with a Mast hight of just under 40 feet above water.
Thanks to ALL that gave input on my questions in the thread for Haverstraw Ny. to Md.
As it turns out we are buying a boat in Cowaton CT. , just up the coast from Stamfort, so the trip will be about the same except coming down the East River instead of the Hudson.
Hoping to make the trip starting the 9th or 10th of May.
Thanks much
Brian
I'm correct.
Thanks much
Brian
