I have been looking at the 6HP extra long shaft (25") because it comes with the alternator installed and I'd like to mount the motor high enough so the tiller can be straight into the cockpit to allow easier throttle adjustment and steering. I've seen C22 sailors struggle with the tiller at awkward angles and inadvertantly changing speed and it appears awkward if not dangerous.Anyone else have a 25" shaft motor installed high on the transom? If so how does it work.Anyone else see any problems in doing this before I spend the money?Thanks,Tim
