Nissan 4 Stroke 6HP Throttle Question
Terry
I have a new Nissan 4 stroke 6HP for my Capri 22. While in gear, if I turn the throttle to the very slowest level (really twisting it all the way clockwise), it shuts off. The dealer has checked it over & says it's OK. The motor starts easily, is very reliable and runs well at slow speeds, just not at the absolute slowest position. Is this characteristic of the motor?
K
Ken Palmer
four stroke
I bought the 5 hp about a month or so ago and it did the same thing. Very frustrating when trying to dock. I just popped off the top and adjusted the throttle linkage a bit to correct the problem. I haven't had any more trouble with it stopping. good luck Ken
Dave
Idle Adjustment?
Isn't there an idle adjustment on that motor? I don't have a four-stroke, but I gotta think it would have that feature like the two-strokes do. On my two-stroke, the idle adjustment is on the end of the twist-grip. It will turn independent of the throttle portion of the grip to adjust the idle speed. Do you have the owner's manual? Maybe you can take a look there to see what adjustments are available.
