Companies like J/Boats use end grain balsa core made by Baltek for many years, but Baltek has made strides on improving the product and I think they now use a product called AL/600/10, which is an improvement from the Al/600, which was a precoated end grain balsa product designed to control moisture permeation. The new AL-600/10 incorporated a new coating that was a third the cost and more compatible with current resins including ortho- and isopthalic-polyester, vinylester and epoxy systems. It has been documented that the best way to use a core material like balsa is to also vacuum bag during the building process. Everette Pearson, founder of TPI and a fiberglass composite pioneer has done lots of testing on hull sections. He once cut out a square from the hull of a J/Boat and dropped it into Narragansett Bay for a few months with the ends open to the sea water. After he pulled it, there was no migration of moisture into the section of hull. He also did ballistic tests where they fired various calibers of bullets into the hull sections and they were impenetrable. The most current method of J/Boat construction is that called SCRIMP which was developed by a guy named Bill Seeman, which TPI used in the production of the various boats they build. SCRIMP is a vacuum bag assisted lamination process where resins are infused through tubes in a very controlled system so that there is consistency over the entire hull (or deck, or whatever they are making) of resin quantity and also it all cures at the same rate producing a very strong, stiff and light product. One downside is print-thru, which is more evident on a very dark hull, but not so on a white hull. Dark hulls show every slight imperfection and so additional preparation must be done for a very fine finish. Balsa core will last if taken care of. People often drill into their decks with temerity and do not properly caulk the fitting they are installing and in some cases it is necessary to actually solidify an area around the fitting or through hull by fiberglassing a larger diameter and then drilling through solid fiberglass and then caulking which insures no migration of moisture will result from such activiity.
