New window trim
Oct 30, 2019
10
Hi Group,I am trying to find new seals for the windows in my Vega. A while back I read a post for new ones and cant remember who had them. The glass is still good, I just need to replace the rubber seals. Can anyone tell me where I can get replacements or suggest other alternatives.Thank youSheila KingPS I love the knowledge you all pass on. I'm having Liza overhauled and have used some of your ideas.
Sep 13, 2002
203
I bought and fitted new rubber seals a year or two ago, I’ll dig out the paperwork and let you know the details. Alisdair From: AlbinVega@yahoogroups.com [mailto:AlbinVega@yahoogroups.com] On Behalf Of Sheila KingSent: 04 September 2013 15:14To: AlbinVega@yahoogroups.comSubject: [AlbinVega] New window trim Hi Group,I am trying to find new seals for the windows in my Vega. A while back I read a post for new ones and cant remember who had them. The glass is still good, I just need to replace the rubber seals. Can anyone tell me where I can get replacements or suggest other alternatives. Thank youSheila King PS I love the knowledge you all pass on. I'm having Liza overhauled and have used some of your ideas.
Sep 13, 2002
203
   For my Mark 1 Vega I ordered the following: FS73 Chrome Filler Strip x 10 metres Door Seals, Rubber Seals, Rubber Extrusions, Window Rubbers UK | Seals Direct WR64 Window Section 5mm x 5mm x 10 Metres Door Seals, Rubber Seals, Rubber Extrusions, Window Rubbers UK | Seals Direct  I made my own tool .. maybe not the best advice.The large cabin windows leaked, and were awkward to replace.The small forward windows didn’t leak, but were a real pain to replace .. and I still haven’t got round to doing the one in the heads.  There’s a ‘knack’ to it .. the first window took perhaps an hour or more to do, the second only 20 minutes.It was hard work, but I’m very pleased with the result.It looks like I have a few feet left over, I didn’t want to take a chance.  Hope that helps,  Alisdair          From: AlbinVega@yahoogroups.com [mailto:AlbinVega@yahoogroups.com] On Behalf Of Sheila KingSent: 04 September 2013 19:05To: AlbinVega@yahoogroups.comSubject: Re: [AlbinVega] New window trim  Thank you.   Very much appreciated. Sent from the iPad of Sheila KingOn 2013-09-04, at 1:04 PM, "Alisdair" <yahoo@...> wrote:
Feb 13, 2010
528
MY big windows were leaking where the
two ends of the rubber come together at the top. I went to West
marine and bought a little epoxy injector( plastic syringe). I put
black rubber sealer that I bought at a hardware store in it and
pushed the small end into the seam and squirted cement in starting
at the bottom of the seam filling and dragging the tip to the top
of the seam then I went inside and did the same. I let it dry for
a week and spayed it good with a hose and one window leaked a
couple drops. After drying a week Squirted some more in pushing
the syinge up from the bottom until the tip hit the glass and
squired some more rubber cement in, That has been 3 years ago and
so far so good, The rubber looked pretty bad on the outside and
the black rubbed off on me every time I got near them. I
scrubbed them and coated them with several coats of the silicone
vynal polish. I recoat in the spring and it holds up until early
fall. IF its too early in the fall I add another coat. With the
winter sun low it's ok until spring. So if yours is leaking at the
joint this may help for a while anyway. I am pretty happy with
mine. Doug
n 09/04/2013 06:44 PM, Alisdair wrote:
Oct 19, 2019
921
Albin Vega 27 Limerick
I found that I could do the large windows on my own but needed an
assistant for the small ones.
Assistant's job was to keep steady pressure on the window glass on
the inside as I seated the glass in the rubber seal.
Once I acquired enough beer to bribe an assistant the job was very
easy - impossible to do the small window seals solo imo due to the
high curvature..
John V1447 Breakaway
Oct 31, 2019
25
Thank you so much. I have ordered the same as you but I ordered the tool. Will let you know how it goes. RegardsSheilaSent from my iPhone
Oct 31, 2019
25
Hi AlisdairMy mechanic and I are trying to install the windows using the new seals but spent all yesterday and only got one of the big windows in. Can you explain the exact procedure of how you got them in. I have the tool and the instructions that come with it are very vague. Please help if you can. ThanksBest regardsSheila. (Liza 634)Sent from the iPad of Sheila King
Nov 8, 2001
1,818
Sent: Wednesday, November 13, 2013 2:09 PM
Hi Alisdair
Sheila. (Liza 634)
Oct 30, 2019
1,459
Silicone spray helps. Use liberally. Nicholas H. Walsh Admiralty and maritime law; Commercial law Nicholas H. Walsh P.A.120 Exchange StreetP.O. Box 7206Portland Maine 04112-7206Phone: 207/772-2191Fax: 207/774-3940 This email is from a law firm and may contain information that is privileged and confidential. If you suspect you received it in error, please delete the email and contact us. From: AlbinVega@yahoogroups.com [mailto:AlbinVega@yahoogroups.com] On Behalf Of steve@...Sent: Wednesday, November 13, 2013 9:57 AMTo: AlbinVega@yahoogroups.comSubject: Re: [AlbinVega] New window trim From: Sheila King Sent: Wednesday, November 13, 2013 2:09 PMTo: AlbinVega@yahoogroups.com Subject: Re: [AlbinVega] New window trimHi AlisdairMy mechanic and I are trying to install the windows using the new seals but spent all yesterday and only got one of the big windows in. Can you explain the exact procedure of how you got them in. I have the tool and the instructions that come with it are very vague. Please help if you can. ThanksBest regardsSheila. (Liza 634)Sent from the iPad of Sheila King
Oct 31, 2019
25
Used silicone in a tube but it dried up before we could get the glass in the trim. Thanks though will try the spray. SheilaSent from the iPad of Sheila King
Feb 12, 2008
337
I haven't done the job, but I'm guessing that ypu might be able to try the technique on a youtube.com video: search for "installing a back window glass with a cord". Good luck tg
Sep 13, 2002
203
A day isn't too far off the mark for a first window. The second should go in lot quicker once you work out the knack of how to do it.I made my self a tool from a piece of wood (an old Vega cleat, but six inches of broom handle would do) to which I lashed a strong U- or diamond-shaped loop of wire (a large brass split pin from the depths of my tool box IIRC, though I did make one with strong SS wire - it just needs to be strong and smooth).The tool is pushed into the channel (rubbers already in the widow surround) and twisted to open it up and let the glass in. There needs to be a lot pressure on the edge of the glass to force it in, and because it's slippy ensure that it can't go overboard .. and has something soft to land on inboard .. if it ends up pinging.When you eventually get the glass inserted, you can run the tool around the seal to ensure there are no curled bits of rubber.links:http://www.sealsdirect.co.uk/bbCMS/...ice-on-fitting-windows-window-rubbersAlisdair
Oct 31, 2019
25
Well thanks all, the windows are in! I found the secret. Since both the opening and the glass were the same thickness we just used the more open grove for the glass. It took us five hours to do one yesterday and we did five today in less than four hours. So glad that job is done. They look great with the little Crome trim in the centre. I'll try to figure out how to put a picture on the website. Thanks for all your great suggestions. I love the chat group and I love my Vega. RegardsSheila KingSent from the iPad of Sheila King
Oct 31, 2019
25
Sorry group about the pictures. I can't even get into the web site. If anyone know how to post photos. Please helpThanksSheilaSent from the iPad of Sheila King
