A
Aldo
I have recently been getting water in the bilge in front of the battery on the port side of the bilge. I know that the classic place that water on the port side bilge comes from the keel locking bolt. I have sealed the locking bolt with silicone sealer and greased it with heavy grease stick and the compartment that contains the locking bolt is completely dry. I had my son pour water into the cockpit drains and found that one of the drains is leaking. (The hose clamps on the cockpit drains are not leaking). He used ice water from the cooler which really helped me locate the leak. It turns out that the funnel shaped part of the drain, under the cocpit, was rubbing against a hole that was cut into the liner that runs just under the cockpit. When someone moves around the cockpit, the floor moves up and down slightly, but enough to wear through the funnel, after 20 years of use. My questions are, has anyone else ever had a problem like this, and how did you increase the clearance hole around the funnel? I guess I'll drill a series of holes and connect the dots with a Dremel tool, but this sure won't be a lot of fun. I'll probably then fiberglass a patch onto the funnel. I'm open for suggestions from anyone who may have had a similar problem. Thanks, Aldo
