Roy Canon
Hi Peggie,I have spent most of the day reading your articles and postings on The Head Mistress forum (plus searching the archives). This is a great service for all boaters!!!My wife and I coastal cruise our 1985 Endeavour 35 sloop along the South Texas Gulf Coast. She has the original manual toilet, 15 gallon holding tank, and Y-valve up-stream of the tank for direct discharge. Because the holding tank has a 3" long split in a top seam, the hoses are old and the Groco toilet has seen better days, we are planning to completely replace the entire system with new components.At this time, I am considering the installation of an electric macerator toilet and a Lectra/San MC (no Type I discharge problems in our area of Texas, yet) using Sealand OdorSafe hose and a Groco bronze vented loop.For your information, the E35 has a large head compartment and good space under the port side v-berth which is immediately adjacent to the toilet location. Also, we have very good electric power resources on board (840 amp-hours). Reliability and ease of use are our two main criteria (because I now know how to control odors from your articles). Cost is a consideration, but it is in a distant third place.If this were YOUR boat...1) Would you choose a Raritan or Jabsco toilet, and which model?2) Would you use a fresh water flush even though this would require the addition of a salt feed system to the Lectra/San?3) Would you install a holding tank in addition to the MSD I to handle potential NDZ problems and/or for a backup?4) With a holding tank, would you add a manual pump for overboard discharge of the holding tank in an "emergency", regulations permitting?5) If you installed a holding tank, would you also install a level indicator/monitoring system? If so, what brand and model?Thanks in advance,Roy Canon
