New to flying gennaker
Nov 9, 2009
69
catalina 25 wing keel rutledge tn.
I just bought a gennaker and am not sure how to rig it properly. My boat is a catalina 25 tall rig. Catalina Direct sells a bail for attaching a spinnaker block to the top of the mast that places the block in front of the headstay. My mast already has a block that is located just below the jib halyard . I have been using this block but am having a lot of trouble with keeping the sail from getting twisted up.The block that I have been trying to use is slightly lower than the headstay. I am also using a snuffer. Should the block that I am trying to use be lower?
Feb 20, 2011
8,060
No, it should be higher than your headstay. Ideally, enough to allow the sock some freedom of movement over the top of the stay.
weinie
Sep 6, 2010
1,297
The spin needs to go forward of the forestay, so you should use the masthead bail.
Nov 9, 2009
69
I have ordered the part from Catalina Direct. The part is called a spinnaker crane and places the block for the halyard above and out front of the forestay.
Aug 1, 2011
3,972
Make sure that however you attach the block to the crane, that the assembly cannot get hung up on the top swivel for the furler. Sounds simple, but it might appear free, and then suddenly not be.
Nov 9, 2009
69
I don`t have a furler.I have hank on headsails. The gennaker does have a snuffer.
