A
Alan
I recently purchased a 1970 22' Catalina for refurbishing at a remarkably cheap price (the amount would astound you). I have been working on it for approx. 2-3 months with a lot of personal sweat equity and obvious aggravation,expense, and satisfaction. Now I am close to baptizing "my baby" in the water and I have a few questions of a "newbie" to this class.1. No bilge pump, drain plug. (I must be stupid but I think I need a manual pump will be needed. Obviously, I'm a newbie to older boats.)2. No mass light plug. (There's lights/wiring but no plug for the mast. Again I assume I'll need to upgrade this as well since the running lights work but mast doesn't have wiring harness.)3. Swing keel (There's no crank to raise/lower the keel so should I assume it's a truly free swing keel? There is a bolt to lock it down however.)4. Towing weight. (The title registers at 3000lbs total w/trailer...is this correct?) My dear wife is scared to death that our new SUV cannot handle this weight although it's capacity is 1 1/2 tons.5. The only fixed motor mount! (I've found a lot of parts at the local hardward store for most things however, does anyone have a home built idea regarding lowering a fixed motor mount for a standard OB motor? $250+ for an fully adjustable mount is just a little too high but if necessary, I'll have to eat the cost. God, the expense goes on and on...hehehe.)Thanks for your information....hope you find a strong windward sail!
