Had problem with steering brake not holding.
So I purchased a kit from Defender.
Pulled all parts off to get access which took about half hour.
Then I worked for three hours trying to remove the brake shoe pin, plus I purchased a new pair of long self locking needle nose plyers, and still could not budge pin.
So I cut an access hole in the pedistal, which took about 10 minutes and using a pair of dykes cut out the pin in 2 minutes.
After removing brake shoes I found one shoe was missing a line'g.
I glued the brake linnings to the contour of the shoes and held them in place using small clamps and let them cure over night. After shoes dried I used Dremel to dress up brakes.
Cleaned up the grease mess and pepaired for tomorrows re installation.
The pin that came in brake kit was too big in diameter, must have been a press fit installation before that's why I had a hard time pulling the other pin, so I installed a smaller pin.
Job done....next install the compass.
http://picasaweb.google.com/1dbpaul...key=Gv1sRgCPaTktmv35ecvwE#5310279894641067074
paulj :troll:
paulj :troll:
