After a long hard winter my Catalina 30 just went into the water and, lo and behold, I had to confront more problems than normal. The first issue concerns the engine controls. I have a tiller and side mounted unit. The fuel control is fine but when I went to shift into neutral from reverse, the shift broke off at the fitting and I was left looking very closely at the knob and broken shaft. I have had some issues with it in the past (difficult to shift into any position) but this is the ultimate result.
Not only was I floundering about, I discovered that the Jabsco head pump was not pushing water, only air even though the sea cock was open. I pump and no pressure. Could it need a rebuild or does is sound like I have some blockage in the water line?
What alternatives do I have with the transmission and fuel throttle on a side mounted unit and what kind of rebuild kit might I need- major overhaul or simply pump?
