Hi Everyone,
I was just given an O'Day 22. It had been my cousins, he had no time for it, and I own a house with dock property on the lake.
It is in functional condition, but needs love. I intend to spend the winter refurbing it.
I have a question about the bilge system and I need help figuring out if I have a serious issue.
The other day I was hosing it off. Sap, leaves, bird crap and getting leaves off of it. In doing so I noticed it had water in the cockpit, so I washed it out and scooped it out.
Despite the angle (I pushed it nose up with the trailer lift) and the amount of water, the water did not appear to leave with any force out the back hole. Water did come out, but it did not empty the cockpit area.
Second, when I went into the boat, there is a hatch right there that I pulled up and there was water in it. I also bailed this out with a cup and removed most of it.
I was spraying water up into the hole in the back (to see if it was clogged with mud) and put a good bit up in the cockpit. At one point, 2 to 3 inches deep. I proceeded to try and clear the leaves and nuts out of the back hole that I thought would lead down to the lower exit hole, but it did not drain well.
So. Suggestions? Educate me about what how the bilge operates. Treat me as if I am an idiot on this, because I am. This is my first boat and I am learning while I go along....
Photos/Diagrams. Detailed explanations are ALL welcomed.
Thank you in advance.
