Help It Is
Sail Net In their latest catalog has 5/16"x65' Halyards priced from $59.95 to $79.95 depending on quality. I replaced mine several years ago with the mast down (boat on the hard for winter storage) but it can be done mast up by end splicing the old and new together. If you think they will fail, do it now.A good roller furler (and this is not the place to cut cost) for the H25 will run close to $1300 for the unit itself. If you purchase it through a dealer who will install it add another $200 to $300 in cost. Then there are the sails to be modified for the furler (luff tape and sun screen) at an additional $200 to $300.As far as painting goes, that is so area dependent. But, if you are not going to do it, make sure you get someone who knows what they are doing. Cheap jobs look cheap and do not last.Hope this helps.
