My guess as well. Bit of oil gets through the rings and there's your puff of BLUE smoke as opposed to black which a whole "nuther story.Run time is only at 20 minutes so rings need to break in -
.................... on a rebuilt engine ?Could be loose valve guides and seals
Just rebuilt myself.
Why not? "Rebuilt" means different things to different people. Did he install new valve guides, ream them properly, new valves, new valves seals, etc.? Don't know..................... on a rebuilt engine ?
That could work ...................... maybe.There's a superb marine engine rebuilder about 3 miles from my house!
I wouldn't be concerned. Give it some time. If it continues to start up easily and run great, what's a small puff at startup. Lots, not all, diesels puff at startup. I've got some generators at work that puff at startup and they continue to run fine year after year.I checked all valve guides, new seals. lapped seats. Everything looked almost new so its not a valve issue. Thanks for the replies.. the motor runs beautifully and fires right up so no concerns.
Same with my 2GM. A puff of grey smoke, then pretty much smokeless, so this sounds normal to me. Ignition is from heat generated by compression. It takes longer to start in cooler weather and seems to produce a bigger puff of smoke then, which makes me wonder if it’s related to how much fuel went into the cylinders before ignition, but my diesel engine knowledge is basic. I can change my oil, filters and impeller blade and winterize it. Anything else and I’m calling my mechanic.……My 2GM20, the same vintage as your 3GM30, coughs grey smoke when I wake it up, then runs smokeless afterward.
Exactly, what is a rebuild to some may in reality an "eye" check and a thumbs up.Why not? "Rebuilt" means different things to different people. Did he install new valve guides, ream them properly, new valves, new valves seals, etc.? Don't know.
Myself, I would take the head to a pro and have all of that done. There's a superb marine engine rebuilder about 3 miles from my house! And, his prices are very reasonable, and turn around quick!
Except the Puff of smoke on startup.I checked all valve guides, new seals. lapped seats. Everything looked almost new so its not a valve issue. Thanks for the replies.. the motor runs beautifully and fires right up so no concerns.
