I am going to replace the Beckson port lights on my O’Day 28’. They are 4” X 10” and the original ones had the little grooves or troughs in the bottom to drain the water. The chandlery where my boat is on the dry and shrink wrapped (they forgot the zipper door for now which is why I am not trying to measure myself) were able to get the entire thing for $100 each.
The problem is when they came in they were the ones without the grooves. According to Becksons web-site these are appropriate for cabin tops with sides that are no more than 15 degrees from vertical. The ones with grooves are okay up to as much as 45 degrees.
Does the O’Day 28 have cabin sides over 15 degrees from vertical? Do I need the same ones as came off? What would be the best way to get an accurate measurement once I can get in there?
Thanks,
Brent
Thanks,
Brent
