New Port Hole Rubber Seals
Rod Hill
Hello, The front port holes leak on both sides of my 1981 hunter 22. Is it possible to get new rubber seals? They are manufactured in Tampa Bay Florida. Thanks from London Rod
J. Tesoriero
Bomar/Gray
If your ports are Bomar/Gray, you may be able can new gasket material directly from Bomar at 1-603-826-5793 or try special order from West Marine. The original Gaskets were round 5/16" foam, now replaced with Bomar T-gasket($2/ft). You will need about 2.5 ft for each port
