Greetings ! I'm gradually getting an understanding of my recently purchased 1992 Hunter Passage 42 (hull # 95) but need help on 2 things:
1) figuring out the wire routing for the forward running lights - which don't work at all (voltage at the pulpit is ~ 6V).
2) a galley switch which doesn't seem to control anything. (picture attached)
The forward running lights only have 6 volts. I'm trying to trace the wires to find the fault. It appears the wires comes up thru the pulpit via a small deck tube on the port side. Those wires feed the port nav light and then a branch wire runs thru the pulpit to the starboard nav light. The main wires are copper and I suspect may not be original. Despite disassembling the V-berth teak (and getting to see the windlass and water tank!) I can't trace the wires. Starting at the circuit breaker I can see the wire goes into 'romex' type wires (contains the + red and the - blk) which then goes up to the 'wiring chase' that houses the stereo speakers. I've taken all the speakers out as well as the TV and lose track of the romex wires. I did however find romex covered wires behind the port settee down by the 'chainplate' (see pic) - are these by chance the wires that feed the forward running lights and if so how do they get up to the pulpit? Needless to say my boat is torn apart and the lights still don't work.
I'm also trying to figure out the purpose of a switch in the galley mounted in the upper cabinet corner (see pics). The wires run aft thru the two cabinet boxes. It is nicely done possibly at the factory but it doesn't seem to control anything. Does anyone else have a switch like this?
All suggestions are greatly appreciated. I've only owned the boat a couple weeks and am still working thru the systems - which are much more complex than my previous boat. That said, we've been out sailing a few times and I'm impressed with her speed and comfort. Thanks again - Jim
