Marcus
I am the proud new owner of a '84 Oday 23, "Ariel" which I recently acquired and plan on sailing in the Boston harbour area this summer. When I got the boat it didn't come with an owner's manual, but Rudy the O'day Guru at D & R Marine was able to provide one. Since getting her in the water and stepping the mast I have come across a couple questions the manual didn't answer, and was hoping someone could help point me in the right direction. The topping lift doesn't appear to have a halyard to regulate the tension, it is just a wire from the top of the boat. Most boats I've sailed have either had an adjustable topping lift or none at all. Is this normal? Does the main take the tension off it when raised? Also, I fortunatly don't have the sticking centerboard problems that appear to be fairly common, but would like to replace the line that controls it's raising/lowering. I can't seem to find access to it from inside the boat. Can anyone tell me where the access is to the centerboard and if it is possible to even change the line?I am looking forward to responses to these questions and from others with whom I will be sharing the waters of Boston Harbour. Thanks.
