Stepping the Mast.
I have a Venture 21 - but I'm guessing the 22 can't be so much different.I don't have a gin pole either. I find that I can raise the mast on my shoulder. But I do need another person to hold the jib halyard to hold up the mast while I connect the forestay. My mast is about 60 lbs so it's quite manageable.I just keep the backstay and the shrouds connected all the time, and just disconnect the forestay to pull down the mast. it's a bit of a pain, and I can't do it alone. But I have been thinking about putting a block on the roofrack of the car that I can use to keep tension on the jib halyard while I connect the forestay.As for motors, I use a 1958 Evinrude 10hp - I'd say it's really too big, I think a 4-5 hp would be more than sufficient. Mine is also a long-shaft model..-=gp=-.
