New owner of a Chrysler 22 sandpiper
May 3, 2025
23
Chrysler C22 Mountain Grove MO
Hello everyone, second post.
About a month ago, I picked up a 1977 Chrysler c22 sandpiper. The PO had kept it in a barn since 2019 and pulled it out last fall. He stated that the boat had been kept indoors for 12 years before I got it and I believe it.
The PO had repainted the boat from the toe rails down with a quality paint a year before storing. The brown spot he said is from a dock rub and it looks like it. She came with a 6hp Johnson, I pulled the impeller and the blades went back straight and showed zero signs of wear. It looks like he had it serviced at the end of his last year and stored it ever since. He kept the sails in his finished basement and the motor appears like it too. Motor started with just a few pulls and runs through the whole rpm range well in a barrel.
He had sealed every opening with steel wool and taped the companionway shut. I was there when it was unsealed. The smell of moth balls is still faint. I think one or two cushions are missing, but the others don't show any stains or wear. The cassette toilet looks like it hasn't been used.
The standing rigging looks like all new cables and the running rigging looks like it should last at least this year without issue. She came with 3 sails (main, and I think a jib and a Genoa). I believe the sails tobe original, they appear almost new and are still stiff like a heavy starched shirt.
The Chrysler trailer is all original except the led lights and tires which were too old to make the trip home, so I threw tires from my flatbed trailer on her. Other than faded paint and the winch is getting replaced, I don't think I will have much work there.
I have been around power boats and a couple times with jet skis growing up, but have zero experience sailing. Hopefully the mast will go up for the first time this weekend and I will have her on the lake in the next couple of weeks.
Here are a couple of pics taken as I found her. Cheers.
632
Oday 25 Milwaukee
Nicely done . You've come to the right place for help and advice . Lot's of knowledge and experiance here . Those were very good boats .
Stepping the mast the first time can be a little daunting . We have 25' sailboat . The first time I raised the mast I wasn't sure how well the experiance was going to turn out . A little planning went a very long way . Welcome
May 3, 2025
23
Thanks to both of you for the replies, I'm hoping to raise the mast by the weekend and with any luck the sails (if it's not windy). I'd like to have her on the water in the next couple weeks
Nov 6, 2006
10,158
Congratulations on the boat! She looks to be in great shape and like Timm says they are well built and sail well. I will echo to go slowly with the mast raising and watch the shroud turnbuckles as it goes up. They can bind and get bent easily.
Get her out on the water and enjoy!
May 3, 2025
23
PO replaced bunk boards when he painted the hull a few years back. He told me that he had only put the trailer in the water maybe 2 times since packing bearings.
When I was changing the tires, I did a shake and spin test on bearings. No sounds and tight, the boat was located in Kansas just west of KC and I live in South Central MO. I checked the bearing temp at 5, 15, 25, and 50 miles on the way home and no issues. It also has bearing buddies. I took fresh grease to repack the bearings with me, but they are fine. I actually worked in Tracker Marines trailer factory as a welder for several years ad grew up on farms so I am comfortable doing that sort of thing.
There is no damage to the keel tray, only damage anywhere on the trailer is the winch was shot so I picked up a replacement, the paint is faded and the only rust is some surface rust near the left tail light on the left side.
May 3, 2025
23
I got the mast up for the first time at the house today. I used Chryslers system from the manual. I don't like it and will be building an A-frame gin pole tomorrow. There was just too much lateral movement and an A-frame will stop that. The pin used to attach the boom as a gin pole also slipped about half way up, my wife was on the winch and I was on the roof lifting, I had to lift it while she slipped it back together, not a good situation. Another argument for the A-frame.
Also, I was able to pull up the Jib and what I think is a Genoa today. I could have sworn the PO said they were original, but both have tags from USA sails (I think). The Genoa looks brand new and shows no wear at all. Saw a couple of spots the size of a pencil on the jib but doesn't look worn. It also has lines already on it. The wind started to pick up so I didn't get to the main.
The PO was attaching the top of the sails with zip ties instead of the hardware on the boat. Is there some reason someone would do this? Maybe as a break away device?
Looks nice.
There is no reason I can think of to use zip ties instead of a halyard. It's not the worst sin PO's commit but it does make reducing sail more complicated. Maybe the PO never went out when there was a chance of moderate wind coming up. That would reduce the days available to sail and leave you with only the dry sailing option. And no anchoring. You'll need to learn and practice heaving to in order to stop the boat for whatever reason.
One caution: If you are going to swim off the boat, I think that plastic ladder is inadequate to re-board. It definitely would be for me.
May 3, 2025
23
Thanks,
I agree on the ladder, he was a pretty big guy, so am I. But that thing looks unused, the stand out feet for it haven't been put on yet.
The sails attachments aren't any kind of quick clip, I think I'm going to look for something different. What it has now is a clevis thing with a pin you turn and pull. Works but not fast. All I could think he was doing with the zip ties was that he could cut them in and emergency or thought they would break away of over power
Jan 8, 2025
179
Compac 16 Pensacola, FL
I'm envious. Years ago I had a Chrysler 20, previous experience being only a 14' homebuilt catboat that got crushed by a falling tree. I thought the Chrysler was bargain-basement, opinion influenced by the K-cars. Until I tied up on the offside of a Catalina 22 and walked across it. The Cataline felt like a tin can underfoot compared to my Chrysler. You've got a good boat there, and you're gonna love the moment when the engine goes off and the only sounds are nature's.
May 3, 2025
23
Well, I finally found a scan of the book that I could make out. Made a set of bridals up and they work perfectly. The mast is much easier to pull up and down than expected. The manual called to use the jib sheet to tie up to the bridals, I used a couple of other pieces of rope in place. I think I will use rachet straps in the future, they will be on the boat anyway and are quicker setup. I'm pretty sure that if they had rachet straps in 1977, they would be used. I will try and get good photos of the setup next weekend.
May 3, 2025
23
I'm surprised to hear you didn't care for the Catalina due to their popularity. My short list was one of those, a McGregor, or the Chrysler. I didn't think I would find the Chrysler. There was another C22 listed in Columbia MO for like 750. Dirty as can be, but looks to be all there with a Chrysler motor and trailer.
Jan 8, 2025
179
I didn't say I didn't like the Catalina. I've never sailed or crewed on one and know nothing about them except that they're very popular, tend to be fast, and aren't built as heavily as Chryslers. My Chrysler wasn't fast at all but I think much of that was due to a severely baggy main.
May 3, 2025
23
Fair enough, sorry to misunderstand. If I like sailing, I will want to upgrade to maybe a Catalina 25 mkII or 250 in the future. This boat is my trainer, I have a pipe dream of doing the Bahamas/Caribbean thing in retirement.
