Hello,
I have recently had a survey completed on a 1987 Catalina 30 Tall Rig sailed only on the Great Lakes. The surveyor said it was in average condition but there are some things that I'm just not sure about. I was hoping you might be able to provide me some opinions. I'd be looking to keep the boat on Lake Ontario with weekend cruising being the primary type of sailing.
Here are some of the comments.
1. Exterior Hull- Bottom paint in good condition. Keel/Hull Joint is visible at leading edge of keel with a 7" horizontal crack on starboard and 6" crack on port (Catalina smile). Moisture meter readings were dry (Used GRP 33). 7" huorizontal scratch in FRP below rubrail on beam, above this area on deck, a 14" crack in toerail at stanchion base. ***This seemed to be the surveyors top priority for me to get fixed and estimated between $700-900. Thoughts?
2. Deck *This is my biggest concern* - All except bow area registered wet with moisture meter- 52" x 7", 38"x8" area along toe rail on port beam, 22"x7" area on bow, 32"x8" area along toerail on stbd beam. Both sides from fwd stanchion gate posts to cabin house at bow and 80" of cockpit sole registered wet. Crazing sighted throughout deck area mainly at toerail. Two 1" chips in gelcoat in fwd bow and 2"x11" vertical chip in starboard cockpit.
3. Interior port bulkhead has 12" x 2" horizontal strip at bottom that is rotted .
4. Chainplates- Possible signs of water infiltration at stbd bulkhead where chainplate washers appear to have slipped upwards.
5. Main companionway is sliding FRP material with bare and worn wood hatch boards, FRP below main hatch is cracked and swelled and appears to have flaking petrified wood flaking out of the crack.
As a new potential boat owner, this kind of snag list has me kind of concerned, specifically the water infiltration and softness on the deck. Am I overreacting to this survey or are these genuine causes for concern? If you have dealt with any or all of these problems, I would be very grateful for your insight.
Thanks so much,
Jason
Thanks so much,
Jason
