New Mainsheet Traveler on 28.5
Oct 22, 2011
4
Hunter 28.5 Athens, NY
Just finished replacing the original, broken mainsheet traveler with a Lewmar size 1 unit, which fit nicely without having to shorten the rail. The approx. five screws on the starboard-most side are threaded into a metal bar, unlike the rest of the screws, which pass through the fg and are held by nuts, accessible from the cabin. The Lewmar requires that all the screws be held by nuts on the inside so I had to drill through the fg and metal bar into the space behind the back wall of the head. Then I used a one inch hole saw to gain access to the space where I would have to install the nuts. The Lewmar rail has a continuous, concealed slot to allow as many fasteners as the original, and at the same spacing as the original, but since the original screws were smaller than the M6's (or 1/4 inch) called for, the through holes had to drilled out a bit. So far so good, until I trial fitted the new rail and discovered interference between the car and the fg. This problem was solved by placing a 1/2 inch thick by 1-3/4 side teak spacer (from Sailor Sams) under the rail, pre-drilled to match the hole pattern of the original rail holes. Now to figure out how to relocate the lazarette cover so the car can travel fully starboard without hitting it.
Likes: finefurn
fhp3
Aug 5, 2012
25
Hunter 28.5 Cataumet MA
I have to do the same to my 28.5. You didn't happen to take any pictures did you? I am thinking of using the Harken 27mm high beam track to avoid the fg issue.
