Jack h23.5
First of all, I think all holes in boat hulls are stupid. This confirms that opinion. Now, I never worried about the plastic plug thingy at the bottom of the mast crutch on a H23.5 since the hole is drilled through the lip external which is outside the boat. Well, today we were finishing the painting and I notice the screw head on the bottom of the boat was wet. So I unscrewed the phillips screw and nut on the plastic plug and water started pouring out...FROM WHERE?? I can look up the hole and see sky??? I took a small piece of wire and bent it and slipped it into the hole from the bottom. It went up then turned forward and went into a void between the bottom of the boat and the inside of the boat. The boat has been out of the water for a month and is absolutly dry inside. A dehumidifier inside assured no moisture even from the air. It looks like there may be a 1/8 inch space inside the almost 1 inch thick hull at the stern. Anybody ever notice something like this before. There are no soft spots, and this is not in a cored area. My intention is to dry it out then fill it as best as I can before resealing it. Thoughts??
