Time to assess the damage.
Well, it's in the driveway and all the damage I expected, was there. One can only shake one's head in disbelief, that P.O.'s would have let the portlights on their $25,000 boat leak, year after year, rather than buy $20 worth of gaskets for the ports. It boggles the mind. The plywood around 4 ports will be swept away with a brush. It's closer to potting soil than wood. The deck apears to be solid, to my suprise. There is some rot around the bow and stern pulpets, but not serious damage. To my delight, the hull is sound and solid. Not a blister in sight. Lucky me. The motor must be original, with uncounted hours on it. All the running gear, of what-ever kind, lines, batteries, cushions, etc. is nearing the end of it's service life. It will be a long, long, restoration project. The chain plates seem solid, just the usual leaks where they pierce the deck. SO the list is clear: Rebed the pulpets and chain plates, replace 1/4 of the wood below decks, new cushions, rewire most of the boat, replace most of the running gear, and I should be good to go. For $8K, not too bad, as I enjoy most of the projects.
