Possible Headliner Solutions
Vincent,My solution was to strip out the old headliner and use a stiff brush to remove the residue. All screws and fasteners were removed, all screw holes were filled with 5200 and a coat of waterproofing paint was sprayed in. The paint was to create a stable base for the subsequent adhesive. In the main cabin, the plywood panels were removed and used as templets for cutting new ceiling panels. This was because it was simpler to make new panels than to clean the old ones. The old panels were spot glued with hot glue and trimmed with a router. The new panels were sprayed with the waterproofing paint mainly to create a consistent substrate for the glue. Marine vinyl and regular car headliner material was purchased at JoAnn's Fabrics. The panels and underside of the car headliner material were sprayed with Permatex Heavy Duty Headliner & Carper Adhesive and set aside for five or ten minutes. The headliner material was lined up, laid onto the panel and a paint roller with a thin nap was used to press the material down onto the panel and excess was trimmed off. Next, the headliner material and the underside of the marine vinyl was sprayed with the adhesive, allowed to dry for a time and the vinyl was laid down and rolled with the paint roller. The panels were flipped over and a 1" border of adhesive was applied to all edges and the vinyl was pulled around the edge and stuck down and stapled with 1/4" staples. The excess was carefully trimmed off. I wanted to use stainless steel or at least rust-proof staples, but I couldn't locate any.The V-Berth ceiling was a nightmare. Pretty much the same as the above except without the panels. Pull down the old headliner, brush off all of the failed adhesive and paint with waterproof paint. Spray the adhesive on mating surfaces of the headliner material and ceiling. Stick the large surfaces down and trim the material to create a smooth surface. Cover with the marine vinyl. Here, all that I can say is to tug it into place and pat down an inch at a time. Not fun!That's about it. The best advice is to just not rush the work. Also: Do as much work outside the boat as you can, especially the glueing. Wear a good dust mask when pulling down the old headliner and vacuum everything thoroughly afterwards. When working in confined areas, get a good high volume fan to pull the fumes out. 3M has a heavier duty adhesive that can be used instead of the Permatex adhesive. Both can be found at auto parts stores. Good Luck,Wes
