New Hunter Owner
2
Hunter Sailboat Anchored
I bought my Hunter in '07 and I just recently got the engine going, then I beached it and found out i have a 3 blade prop and very lose from side to side and from bow to stern my queston is....How much play is there for my prop, and what size should it be? I have one more question too....Recently after i got the engine started about 3 days after the impeller went out how do i change it?:confused:
Nov 8, 2007
1,594
Some answers
Play of the shaft. If it's 1/8 inch side to side, then you need a new cutlass bearing. Fore and aft - I don't know. I would want to have a look at the coupling aft of the engine before getting concerned.
Prop size - the original was 2 bladed with a diameter of 12 inches, and a pitch around 9 inches. I wouldn't worry about the prop until you know how fast the engine and prop will drive the boat, and how the engine behaves on the top end.
If I weren't getting any vibration, and engine will drive the boat at 5 knots, then I would focus elsewhere for a while.
The impellor is behind a plate held down by screws at the lower front of the engine. I'd search the archives here, or better yet buy the book on diesel maintenance on this site for a procedure on how to change it - it's an easy job!
Good luck - you have a great cruising boat!
Mar 31, 2010
2
Hey david Thank you for your reply, But I think i wasn't clear. My prop has play not the shaft....The impeller i just change it without removing the pump housing? Thank you
Nov 8, 2007
1,594
Snug fit
Your prop has to fit snug. Either the nuts are loose, or the prop is not matched to the shaft. If the latter, you need a new prop. For the former, you should just be able to tighten the nuts.
