My mooring in strong tides
Where I've been moored out in the harbor for the past five years, the tide can be as strong as eight knots. Additionally, the sudden storms can be rather taxing on a mooring.I've got 100' of 3/8" galvanized chain leading back to the boat. This leads to a pair of 20' pennants shackled to the chain's end (5/8" Nylon line).I chose not to use a swivel, as it was one less thing to go wrong.I've seen numerous mooring/pennant failures here, and 96% of them were mooring ball failures, where people used the built-in swivel feature of these balls. Even balls without a swivel feature have failed. Thus, I don't use a ball at all. The pair of Nylon pennants create a bridle afront the bow. When properly adjusted, this bridle prevents either single line from chafing across the front edge of the bow as the boat swings from side-to-side, as Hunters tend to do at anchor.Attached to the boat end of one of these pennants, I have another line to a 90" masted mooring buoy. When leaving the mooring, I drop the lines over the side along with the buoy, and recover the buoy upon returning. The lines sink to the bottom and lay there.Another nice feature with two pennants is that you can tie your dinghy off to one which leaves the other free to bring aboard. I learned this lesson the hard way when a storm suddenly broke out as I approached my mooring. It was murder trying to pull the pennant aboard with the wind-blown weight of the dinghy aggressively pulling the line away from me. Now with the mooring buoy, it gets tied to the free line. At least I can get the boat tied-down before dealing with the pennant attached to the dinghy.Yes, the two lines do tend to wrap, but I've given up worrying about this. I used to release one of the lines to undo the wrap, but eventually discovered nature will take its course, with the wrap prompting the boat to pivot in the opposite direction during slack tide. I think the bridle has some part in this prompting.Another hard-learned-lesson was to NOT have an eye-splice on the boat end of the pennants. It sure is easy to slip the eye over the cleat, but try to release it during a heavy blow and you'll never use the eye-splice again. The entire weight of your boat is pulling these lines taunt. Getting enough slack to slip the eye off the cleat is nearly impossible. At the time, I had another boat dragging down upon me and nearly had to cut my pennants.Under such circumstance, it's so much easier to simply release the line. I can't now recall why I couldn't simply motor forward to get the slack, but know at the time there was a reason. I ended up having to attach a block & tackle down the pennant and back to the bow just to get the necessary slack for release. What a pain in the butt that was.Ahh... live and learn.ScottKey WestS/V Rubicon
