New headsail for my H23.5
75
Hunter 23.5 Lake Keowee, SC
Thanks for the great help in the past from other contributors! My headsail needs to be replaced and I am thinking of buying a Genoa instead of another Jib. The wind here at Lake Keowee in South Carolina is pretty light most of the time . . . So what size Genoa? 110%? 150%? I have no interest in roller furling, so I can still use my Jib or a Genoa. Does anyone have any thoughts? Ideas? Comments? Anecdotes? Thanks in advance! Captain Bob
Jun 2, 2004
3,612
You'll Have to Add New Cleats, Winches , etc
To get any larger a headsail the sheets will need to go on the outside of the shrouds then you'll need somwhere to attach the sheets.
Jun 2, 2004
649
Hunter 23.5 Calgary, Canada
Jib size on a H23.5
I've had my H23.5 for 4 seasons now. This question comes up now and then. I think I asked it myself when I was deciding between modifying my jib or buying a new sail when I went to install roller furling. You could probably find discussions in the archives. Anyway, my observation is that there is a concensus that one should _not_ increase the jib size even if you don't mind adding all the extra hardware. The H23.5 (and 240/26/260) is a fractional rig, meaning that the mainsail is the driver, not the jib. Adding a large genoa would throw off the balance of the boat. Perhaps that's not a problem in lighter air, but if you switch back to your old jib for heavier air, you're back where you started, which is saying that your jib needs replacing! I got a whisker pole just a week ago for downwind sailing. I only used it for about 10 minutes but so far I think it's great to have. Funny how some people have no interest in roller furling. I single hand a lot and wouldn't be without it now. ...RickM...
E
Ed
110% Standard?
I think a 110% Genoa is standard on a 23.5. Rick M. is right in saying that a larger headsail is not the way to go and most of the discussion threads here on the subject also agree. I also agree with him on the roller furler for single handing. Rick W. has a valid point with having to add a lot of extra hardware with the larger sail. I toy with the idea of a drifter for when the wind dies in the evening but look at the cost an decide to just enjoy the boat as is. Rick W. - Did you ever get arounf to adding the extra bow cleats?
Jun 2, 2004
3,612
Ed MIssed your Posting
I have not yet added the cleats. I wanted to ask and now forgot about access to the mounting underneath.
