New Hatch Runners
78
Oday 22 Erie Basin Marina Buffalo, NY
I'm installing new hatch runners on my O'Day 22. My question is what is the easiest way to remove the teak bungs. I've been digging them out with a knife, but it's really slow going. I thought of drilling but I'm afraid I might mess up the screw heads and create another removal problem.
Pete
Jan 24, 2005
4,881
Oday 222 Dighton, Ma.
Pete
Hi Peter!
You need to preserve the shape of the hole in the Teak so that when you install the new bungs there won't be any uneven surfaces or gouges around the bung after you have sanded it flush with the surface.
The way I have always removed bungs is a technique used in a book entitled "Boat Carpentry" by Hervey Garrett Smith. It's a very old book and the techniques are probably dated by today's modern standard.
He uses an old fashioned egg beater drill for this tool. He takes a small wood screw and cuts the head off it. Then he inserts it into the chuck and uses it like a drill bit by drilling into the center of the bung. When the tip of the screw hits the top of the screw head under the bung, it causes the bung to rise,- so it says in small print. However it does work most of the time for me.
I have an antique miniature chisel tool that has a chuck for some small chisels that are stored in the wooden handle that I sometimes use to carefully remove parts of the bung that the screw bit can't remove.
Last summer I picked up and old fashioned Craftsman egg beater drill brace that has the bits in the handle for $ 9.00, and I keep it in my ditty bag on the boat.
When you install the new bungs, probably 3/8" Teak bungs, you want to have the grain run in the same direction as the surface wood.
This guy does it a different way. Check it out.
http://www.youtube.com/user/brandotown?blend=1&ob=5
Good luck Pete!
Joe
Oct 10, 2009
1,120
Beneteau 393 Muskegon
Joe's right - that method works like a charm. I just use my cordless drill; first a pilot hole because I don't want to crack the bung and have it come out in pieces.
I've not cut the point of the screw off, but that seems like a good idea because I'm always worried I'll hack up the screw head.
Dec 24, 2010
78
Thanks Joe,
I knew you'd know what to do, I should have emailed you directly. At least with a post here others will get this handy tip. I don't have an egg beater drill but I do have a hand brace. I will pick up an egg beater at Sears or Home Depot since it will be easier to control than the hand brace, (also easier to stow on the boat). Thanks again Joe.
Jan 24, 2005
4,881
Thanks Joe,
I bought one at a local hardware store that I paid about $12 for and it works but I need to hold the chuck from pulling off with the worm gear when I try to pull the bit out of the work.
Prior to that, I had bought a new fangled egg beater drill from Sears and something broke in it and the salesman at Sears told me that they don't guarantee this certain product because it wasn't made for Sears.
The best one that I found yet is the old fashioned one that Sears sold with the wooden handles that can be found in the flea markets.
My son bought me a battery powered Black & Decker Pivot Driver that would come in handy for on the boat jobs. This one doesn't have a variable speed though. I'm sure that one of the other brands would have one with a variable speed. It resembles a miniature electric drill and you can twist it around so that it looks like a fat screwdriver. It has a special chuck on it that takes bits and sockets made specifically for this tool. It really wouldn't be applicable for this job unless you're using it for an electric screwdriver.
I've used a regular brace to screw into bung holes though.
Actually, Indysailor came up with two good tips on using this technique.
1. Drill a small pilot hole into the center of the bung first and then use the wood screw bit to raise the bung with the brace.
2. Cutting the point of the tip of the screw bit so that it doesn't bugger up the screw head under the bung.
Chances are, the wood screws under the bungs are stainless steel and they aren't likely to get mess up by a Mickey Mouse screw bit. Then again, I guess that you could always use a brass screw for the bit because it's a softer metal, and leave the point on it. Try experimenting and let us know how you made out.
Joe
