C
Chris
Good morning I own a 98 26H and it is time to replace both the main and jib halyards. The manual says for themain halyard 5/16 (8mm) LS small eye D Shackle 88ft Bluejib halyard 5/16 (8mm) LS small eye D Shackle 80ft RedAccording to other posts I have been reading they suggest going down one size in thickness so as to make it easier to raise and lower the sails. Has anyone with a H26 or H260 replaced there halyards? If so what did you use? And where did you order it from? Thanks in advance Chris sv Charisma
