I thought that RC’s questions strayed from the keel bolt thread. So here is a new thread. RC writes: "Thanks for the picture. It is the first time I have seen the C37 keel. Do you have a shot of the rudder as well? I have seen rudders on these in two forms, one with a short detached skeg, and another with a full length skeg. A picture or two would be helpful."ANS: One is attached, not the best. I have never seen an H37C rudder look differently except one and it was an owner modification."There are two things noticeable about this picture, first, the keel is longer than usual, and second, there is quite a bit of hull below the waterline. Both are good." ANS: looks are deceiving. The picture was a shoal draft keel. The stub and the fore/aft dimension are the same as the fin keel. The fin keel is 12" deeper and thinner(lighter)."This brings us to another question. I have noticed the club staysail has "pushed" the mast back farther than usual. Do you have enough rudder to hold your course when close hauled with the rail in the water? Or does the boat turn into the wind on it's own? This is a huge question, and be sure I'll read any and all responses I get." ANS: all cutters have their mast further aft, to make room for two headsails. So yes, the boat is not balanced if you sail as a sloop in 20+ winds. Mine has some weather helm but it is minimized because I have an oversize yankee(jib). I am not sure it is any better or worse than a sloop with the rail in the water. And we all know that is not the way to sail the boat don’t we? The owner modification mentioned above was to add to the leading edge of the rudder, about two inches I think. He felt it provided better steerage under all conditions.
