specs state:
Total Amps: 15 Amps
Number of Outputs: 2
Amps per output: 10/5
Looks like it is designed for two banks but will take forever to charge them.
This is one of the main reasons I often prefer a single output charger. My preference, in a great value charger, are the Iota's.
When combined with an ACR or an Echo type charger they work very, very well and all the switching etc. is done behind the scenes. Many of the chargers out there claim 15A BUT when you read the lit you really only get 10A & 5A or a true divided output. The main problem with this is that often times the starter battery will be accepting less than 1 amp so you'll have 4+ amps totally wasted and only 10A for the house bank no matter what the start bank is accepting in terms of amps.
Iota chargers like the
DLS-30 IQ4 with the IQ4 smart controller are less expensive per $ of amp output, hold up well in the marine environment, are extremely reliable, and use single output so you can use an ACR or Echo charger to get the full rated output of the charger, if needed.
A Xantrex 20A True Charge is $241.00 at Defender but with the DLS-30/IQ4 you get 10 more amps for significantly less money, about $160.00. That $80.00 +/- savings will pay for an ACR which is an excellent upgrade.
An ACR (Automatic Combining Relay) automatically combines your batteries, for charging, when they sense a voltage over 13.2V and automatically disconnects when the voltage drops below about 13V. It takes the place of a human selecting BOTH, only it does not forget. They will work for ALL charging sources such as alternator, wind, solar and battery charger. Blue Seas makes an ACR that can be had for about
ACR $77.00.
