I installed a new cutlass bearing along with a new shaft. Everything felt fine during dry fit and the bearing pressed in easily. After getting everything installed the shaft seems to have too much turning resistance.
Is this normal and something that will loosen up with some run-in? I can understand it being tighter considering the old bearing and shaft were badly worn, just curious if it’s normal to be tight when everything is new.
