new control device
May 20, 2016
3,015
$80 for a regulator that looks like it can do constant current as well constant voltage on a program. Signal K is good, but may require you to implement a Signal-K to NMEA-2K bridge. There are tons of ardunio's out there so that is fairly stable (assuming the software is ok) -
I didn't see belt/small motor/alternator temp derating - all of which I consider a necessity
Les
Ted
Jan 26, 2005
1,273
Interesting, that article was written on Friday, May 8, 2020. Is this future technology? :)
Likes: justsomeguy
Jun 28, 2005
440
Hunter H33 2004 Mumford Cove,CT & Block Island
If you look at comments you would have seen the "date" explanation.
I have copied it below;
"Viking StarMarch 1, 2017 at 11:53 AM
OK, a LOT slow - but I think I get this comment now...
The dates. Well, I figured out I can force placement of posts by using different dates. Hence, this into page is 'posted' some time in 2020 - which makes sure it is the 1st displayed page. (Actually, look at the bottom to see when updated it)"
