New charger and invertor location
35
Oday 34 Fort Myers
I just purchased an O'Day34 and bought a new Xantrex charger and invertor to upgrade the electrical. I want to install the charger and inverter under the cockpit hatch in the engine compartment.Its not to close to the diesel. Does anyone know if there are any problems with the heat or ventilation, when installed there.
Dec 8, 2006
1,085
Oday 26 Starr, SC
Charger location
I am not comfortable with your idea. I suggest that charger should be away from engine compartment, as maybe under settees. May have to buy some longer heavy gauage wire, but potential for spark or heat away from engine.
Address the question to Main Sail one of the moderators on forum. He is resident guru on such matters.
Ed K
ChrisP
Sep 28, 2008
11
Tranc Pac Eagle 32 Goderich, On.
Last year I installed a new Battery Charger on my 34. I positioned it in the quarterbirth, on the engine room bulkhead forward of the access panel next to the companionway. It is out of the way, has excellent ventilation and good access to the batteries and electricals.
Chris
RAD
Jun 3, 2004
2,330
Catalina 30 Bay Shore, N.Y.
Looks like Chris P gave the answer and I agree that mounting next to the engine is a bad idea....electronics don't like heat and if you look in the installation manual I'm sure there's a temperature range
May 2, 2011
35
Oday 34 Fort Myers
Thanks Chris P, I agree, I like the idea of locating it in the quarterberth, that keeps it out of the engine room but conveniently located near the batteries. I am thinking of mounting the inverter in the cabin on the bulkhead to the right of the shore power panel, this also would provided for convenient wiring. Any thoughts are appreciated.
