Dan Nease
This last Saturday (July 1) I ran aground while underway. Needless to say the centerboard split leading edge and trailing edge. The internal board (wood) was not broken, but we proceeded back with caution to the dock for an inspection. My question is should I repair or get a new centerboard? If new where could I get one. Also we took the opportunity to accurately measure our draft and discovered that we didn't need to put the board down all the way while sailing to windward. After we got the centerboard back up in the trunk(so it would trailer), we pulled out only 29" from the keel and went back out averaging 20-30 degrees of heel easily catching and passing a Catilina 25. So how much board is needed without laterally slipping through the water?
