I've been a bass fisherman all my life running 21 foot fiberglass hulls, 200 HP outboards, 110lb thrust trolling motors,
electronics, basic DC wiring, bilge pumps, live well pumps, etc. but I'm struggling to get my head around all the sailboat and sailing knowledge.
Currently I'm needing to replace my pvc plumbing lines (they've never been replaced and are really, really gross) in the galley sink, ice box, head, etc. I'm attaching a "crude" diagram showing my plumbing lines running from the galley sink and the ice box to the thru hull. There's a "T" connector with the galley sink attached on one side and the ice box drain hose on the other side. The drain from the galley sinks takes a 90 degree/sharp turn to miss the top of the highest draw under the sink, winds its' way behind the ice box and then has to come up 3-4 inches to the thru hull. The drain from the ice box slopes down and runs along the hull past the thru hull and then makes a bow and comes up 3-4 inches to the other side of the thru hull. I don't understand how water would easily drain via gravity down and then back up thru the thru hull. What keeps water from backing up thru an open thru hull into the lines?
Can someone please explain how this works or point me to a good resource. I can't stand not knowing how stuff works. Also, when should my thru hulls be open and when should they be closed?
Thanks in advance for sharing and helping me get squared away. I love working on my boat and my family and I are loving learning to sail. Whoever said you can't teach an old dog new tricks sure didn't know me! God Bless guys for help a "moroon" like myself <grin> ...
