Hello fellow C22 owners! I picked up a 1978 a few weeks ago and have been slowly getting it sorted out. This is my first sailboat and I have been doing a lot of research and love all of the discussions here and resources available for the C22. However, there are a few questions I have that I have not found an answer to and thought I'd bring them here.
1. Why is there no drain holes between the cabin sole and the bilge? Water sits in the pans in the main area and under the table. Has anyone drilled a small hole to allow water to flow into the bilge? Is there a reason to NOT do this?
2. The bilge layout, because of the keel locker, doesn't allow water to flow to where a bilge pump is installed under the aft seat of the dinette. Has anyone found a way to move that water to a common area? This may not be a big deal as I fix a couple minor leaks that allow outside water into that area, but curious about managing small amounts of water in the bilge.
3. I've seen people use storage bins with lids in the different storage/bilge access areas. Does anyone have recommendations on which size, type, brand of bins to use for this? I'm looking to store spare parts, tools, etc. on the boat while it is stored.
4. How do you keep your paperwork on the boat? Registration, etc. I'm thinking about a water tight case, like a pelican.
Appreciate any replies and insight!
