Carpeting in your boat
Hi, I have a 380, my previous boat was a 36 and I carpeted it. I'm a journeyman liscensed carpet installer. The carpet is easy to install, if you choose to do it yourself. I would suggest a "cut" berber and place non skid under it. Yes, it will be exposed to foot traffic and dirt, sand etc., however it is easy enough to take outside and shake clean. Use a tapers knife (utility knife) and lay the carpet so it overlaps all the areas to be covered. Then kneel on it so it remains stationary and rough cut it to the size you need. Then fold it back from the wall and while keeping it close to the wall cut it from the back. Always cut it from the back!!!!! I would serge the the edges. It gives a more professional look and keep it in two sections, so it is easy to remove for cleaning. If you need some specific info on some of the carpets on the market just email me and I will be happy to make professional suggestions to you. sail1752@aol.com good luck Gary
