Ah, yes
Because of your address, I assume your dealer is close by, thus making the question less critical. Periodically make a list of problems and give it to him.Things that are good to check: engine alignment, check to see if fan belt pulley rubs against insulation, check for minor leaks like a strut bolt seeping, make sure mast is tuned and doesn't bend in a hard wind, make sure you know the operation of all systems, check marine radio for interference, check to make sure that the tube in the top of the cabin accepting the wires from the mast has been caulked from above to avoid leaks in this area, check reefing system to make sure it is working properly, check meters, gauges, etc. for accuracy (especially knot meter - check this against handheld gps), check to see if the compass has been appropriate adjusted for your sailboat, if you have an autohelm, make sure the compass on that agrees with the boat compass, check stanchions for tightness where fitted to the deck or at the bottom fitting, check to see that all doors and hinging platforms fit properly (v-berth platform had to be modified).But most of all, enjoy as both Hunter and your dealer are behind the boat. Its like a new car, there may be a few minor problems, but in total, you'll enjoy your new acquisition.JimH340
