New boat startup?
159
Catalina 387 Hampton, VA
This may seem dumb to most of you, but you all started somewhere. I am getting a new un-used boat. It has a head on it, what is the proper way to condition the unit for use? I have seen the KO stuff and will pick it up, but should I have that in there first or ?????
Dec 2, 1997
8,961
- - LIttle Rock
Put it down the toilet with the first flush
That's all there is to startup...except read the directions on the bottle and follow 'em. You might want to check out the link below to learn how use and maintain your plumbing and prevent problems with it (and cure 'em if you fail to do what you should have done to prevent 'em).
