New beneteau Owner
sante
Apr 20, 2009
10
2 Oceanis 321 Fort Lauderdale
Hi,
We just purchased our first Beneteau, an Oceanis 321 from 1996. We had the mast stepped and are having problems raising the sail. Any pointers would help. Our engine is a Yanmar diesel and yesterday we noticed all of the transmission fluid had leaked. The transmission is a Kanzaki KM3P. We are in Fort Lauderdale and would like to meet fellow Beneteau owners as we are new to sailing.
Hugh & Tad
Jul 8, 2005
522
Jeanneau 389 Grosse Pointe Farms, MI
Hello, Hughtad.
Send me your contact info to my email address and I can try and help you. We have a 2000 year B321.
Chris
cymeyer1@gmail.com
Jul 8, 2005
522
For the sails, you need the lube sold at most sail stores to spray on the sails as they go up. We could not get the sails up each year without this stuff. I think it is called "Sail Kote" at West Marine. It is a dry lubricant.
On your gearbox, you said all the fluid leaked out. It is normal engine oil I suspect. It is not special transmissio fluid that I am aware of... If it leaked out on it's own, you may have a bad seal some place....
DougM
Jul 24, 2005
2,242
Beneteau 323 Manistee, MI
The lubricant is called Maclube and its by Harken.
There may be some hardware binding in the furler that needs to be checked as well.
Don't be too sure that the gaer box oil is plain old motor oil. It could be 90 weight gear lube or it could be automatic transmission fluid. You nay have to hunt for information about the gearbox.
I suspect some seals have dried out most likelly the shaft seal.
sante
Apr 20, 2009
10
Thanks for the informmation. It is definitely transmission fluid. It is pink. The boat was out of the water for a few months so hopefully it is just a seal.
Jul 8, 2005
522
I have a 3GM30 Yanmar. THe manual says to put SAE30 lube in the gearbox. I need to change mine. I will check with the Yanmar dealer to see what they recommend.
4
40 footer
Welcome to boating
Welcome to the Benteau group... i have a Beneteau Oceanis 400 and also provide marine servies to various clients. We are based in Miami but if you can not find good services where you are fee free to give us a call 305-495-2300 or email jschfp@comcast.net
Jeffrey
Hugh & Tad
sante
Apr 20, 2009
10
Great News
We had our boat's engine serviced today and the liquid was diesel and water!!
The engine is now in great shape so we are heading out to the intracoastal and ocean this weekend!!
Pictures to follow after our maiden voyage on Sante!!
Thanks for all the advice and calls, I bought the lube today too so Ill let you know how that maunsail does.
Regards,
Hugh
