new battery charger install, & new solar panel project....
MitchM
Jan 20, 2005
1,031
just got the info i need from maineSail's great site...my 2 spring projects are : #1-- install a whole new shorepower and battery charger system into a com pac horizon cat i'm restoring , and #2 --install a flexible solar panel onto the bimini with a MPPT controller and nice deck gland. after a lot of internet browsing, searching i found MaineSail's how-to articles. i just ordered up the battery charger from him (and a compass marine hat..) . his writeup on solar panels was very helpful, and it looks like i'll be ordering the Solbian flex panel setup he recommended. (he's now a dealer for that panel, which has tremendous weight advantages over the rigid panels.) ( then i found another project of his: new teak veneer stereo box .... might make that #3. )
fair winds and a lot of work ahead....
May 27, 2004
2,056
For those who may not know of Compass Marine, could you post a link to "Maine Sail's" web page regarding the solar panels?
Thanks,
G.
Very interested to hear how your solar install works out. We are considering doing the same, but I’m on the fence about what panels to use. I don’t doubt that the Solbian panels are the highest quality, but they come at a serious price premium that makes them hard to justify for my pretty casual use. I can find panels for much less that claim to be SunPower cells, and I’d take the chance with them if it were just a matter of the panel cost. But I’m nervous about having my Bimini tailored to attach one brand of panel that might not last, leaving me out not just the panel cost but also the custom canvas work.
Thanks,
G.
www.MarineHowTo.com
Take a look at this article by Nigel Calder. One of the most informative I have read.
Feb 17, 2006
5,274
I am using a Renogy 50W panel on my boat. Works great. Have had zero problems so far. My panel is rail mounted, not bimini mounted. YMMV
www.MarineHowTo.com
I’ve seen that article, and I agree it’s a great summation of the various considerations. But when I look at, for example a 170 watt SunPower branded panel for $400, or a 145 watt panel with “SunPower cells” for $725, or a Solbian SR 144 watt panel for a whopping $1316, how can I tell the difference? The lower cost ones are from US dealers, not random Chinese knock off sites. I’m sure there’s some amount of getting what you pay for, but no where can I find actual data other than “knock-offs are bad, Solbian are good because they use genuine SunPower”.
Look at the efficiency ratings and look at the physical size for the wattage. I bought a couple of Solara panels because they use the good SunPower cells and wattage per square foot was higher than others in a similar range.
SunPower sells different grades of cells. So a panel could legitimately have SunPower cells, but these might be lower grade cells. The higher grade cells with advanced construction generate more power in lower light conditions and are less affected by shading and overcast skies.
From all that I've learned, solar panels seem to be the Wild West and you get what you pay for if you buy from a reputable dealer.
No help there in my case unfortunately. The $400 panel is 8.51 square inches per watt. The $725 one is 7.71 square inches per watt, and the Solbian is, in theory, the least efficient, at 10.1 square inches per watt.
Well that certainly seems to be the truth.
