		Mark Mowery
I installed a 16,500 BTU Mermaid Air Conditioning Unit with reverse cycle under the settee berth at the nav station. I have only run the unit for a few hours and I did run it with the locker wide open for an hour. Later I closed the settee compartment up, but I am not sure that I may still have a potential freeze up problem or not.My question is what are the conditions and the preventitive measures against freezing up of the coils?My dock buddies were trying to tell me that this is a common problem on any boat. Their suggestions were to insulate the compartment that the unit sits in very heavily because it is thought that when the unit draws air from the compartment itself that is what causes the freeze up. In my installation the return air is 14x10 and the unit is mounted flush with the return air grill, so very little air is drawn from the settee compartment itself.Any suggestions? Is freeze up of the coils going to be a problem or a once in a while thing? I can always run the unit in reverse cycle for a few minutes to clear it, but that's a hassle.
